STEP7 LITE to S7
DannyRitiu
Oct 2010
Tg Mures
Hello everybody!
Is there any possibility to open a STEP 7 LITE project file (*.k7p) with STEP 7?
My STEP 7 is version 5.4+SP3, I don't know about the k7p files.
Thank you!
hi,
When exporting with STEP 7 Lite, export the complete user program as an *.awl
file or the entire symbol table as an *.sdf file. After the export is finished, use the
menu command Insert > External Sources to import the *.awl file into the STEP 7
project or the menu command Table > Import to import the *.sdf file into the
STEP 7 project
To export to STEP 7, proceed as follows:
1. In the project window, select the "Program" symbol or the "Symbol table"
symbol, as appropriate (If you want to export both the program and the symbol
table at the same time, press the CTRL key when selecting the second
element).
2. Select the menu command File > Export > For STEP 7
3. In the dialog box that appears, select the destination folder.
The form in which the selected elements are exported depends on the identifier
option that you select ("Absolute identifier" or "Symbolic identifier").
4. Select the name of the export files without including the name extension. The
file name to be created will be shown along with its path information in the
"Created files" field.
5. Click on the "Export" button.
6. For a description of how to import into a STEP 7 project, please refer to the
"Help on STEP 7" (See the topics "Inserting external sources" and "Importing a
symbol table").
best wishes
Paresh
Other solution please!
Hello,
First of all, thank you for your kind answer.
Unfortunately, I don't have the LITE version anymore and I only have the k7p files. Is there any possibility to open them this way?
Thank you!
Hi Guys. I have worked with S7-200 processors and some from AB. Now I want to learn S7-300 and I would like to know what version of PLCSIM can be...
7,215
Hi, now that Siemens has slashed the price for STEP7 lite to approx 50 EURO (according to a newsletter that I recieved), I wonder if this could...
6,711
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
137
