Step7 Micro/Win to configure CP243-1
Vadagor
Jul 2017
Barcelona
30
Hi everybody!
I need to add a network module CP243-1 to an existing S7-200. I'm using the Step7 Micro/Win to do the configuration. I try to follow the instructions but, when I press the "Read Modules", to know its location, the CP243-1 doesn't appear.
I can download/upload the programs to the S7-200, run/stop it, etc., everything is working fine.
If I connect an Ethernet cable from my laptop to the CP243-1, the module turns its leds on (Link and Rx/Tx).
I can't put the CP243-1 in Run mode, see it on the Ethernet Wizard, and the SF red led turns on eventually (it is not always on and it is not blinking... it just turns on from time to time).
I tried to configure the module configuring its location manually, configure the ETHx_CTRL, etc., but I can't ping the module. It is like it "doesn't connect" to the CPU.
Any suggestion? I am thinking about a hardware failure (connection between CPU and CP, flat cable, CP module....)
Thanks in advance!
Nick
To add more information, here I add two images. In one, you can see a CP module in the lower window (this is what I should get) and the other, with a greyed window is what I actually have. :mad:
Cheers,
Nick
Hi everyone!
Just for the record: there was no mistery here. I could configure the module on site without any problema. Apparently, the CPU, I was given to test, had its communication port ruined.
Thanks everybody!!!!
Nick
Just when you think your problem is solved..... new problem! My Siemens rep came through with with the Step7 Micro/WIN software I needed for a...
6,921
I have an opportunity to quote an HMI project for one of my customers. It's a small project, and the customer is not the type with deep pockets...
24,856
Problem 1: I'm concatenating some information as I go to a symbol, let's say, VB50. After I send the info to the touch panel, I need to reset it...
2,840
when i compare the program from the plc with the one in step 7 i receive several differencies.Cause?
4,200
I couldn't find the Step7 micro/win manual at the Siemens site. Is it free for downlaod and where can i get it, or I've to pay for it. There is a...
19,969
