Step7 - Modify Value and Force Value
hcjs123
Oct 2020
Korea
I have interface test between Quantum PLC and Siemens PLC.
When I change the output value in Step7 by "modify value", Quantum PLC receive the signal, but does not maintain the steady value.
Even though the modified value in step 7 maintains the steady value, the value in Quantum become zero and restore "modified value".
I think that Quantum PLC may reset the value once and restore.
If I give "Force value" in step 7, does Quantum PLC maintains the modified value ?
I used gateways between S7 PLC and Quantum PLC.
For the first time, I used "modify value" in S7 PLC.
The modify value does not change in S7 and gateway. But, modify value in Quantum PLC change from value to 0, from 0 to modify value, by keep changing.
Today, I used "force value" in step 7. The situation is same.
Finally, I found that the Quantum PLC have two communication setting.
When "Clear Timeout" is set, the last value is set to 0.
When "Hold Timeout" is set, the last value stay.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
147
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
140
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
526
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
543
