Step7 MultiProject Transfer
Disciple
May 2012
Bay Area, Ca
53
I am Having Trouble copying MultiProject files from my Laptop,(#1) to my external Harddrive, then to my other Laptop,(#3). I do the same thing/s I did for my laptop(#1) and another Work Laptop(#2), and now I'm having an issue on Laptop #3 in which all the Procedure seems good, but when I go to the saved Project file on Laptop #3,& open it, there is no CPU. I'm currently Removing Step 7 V5.3 from Laptop 3 and going to Reinstall. I am getting error message #257:5 when I open Simatic Manager " Server 's7hstatx.dll' for _S7H_Station_AT objects could not be loaded". Make sure required software packages are installed. Also getting Error #257:5 "One or more objects or a type cannot be represented. Server 's7hprxyx.dll' for objects could not be loaded. Make sure required software package is installed.
Thank You
Check for Installed software under help in simatic manager. Maybe You're missing something as previous poster suggested.
I had sort of a similar problem and had to upgrade my Step 7 software to v5.5 plus make sure to install newest hardware updates.
So, Even tough Laptop #1 & #2 are working fine, I will go to the Siemens website & search for :
The Latest Hardware Pack/Newest Upgrade for Step7 V5.3?
I'm Going there right now.
Thank You
Currently Downloading the
'Simatic_S7_Step7_V53_SP1' File from the Siemens Site.
Does anyone know if this is the Most Current or Must I go Thru all the Files under the Search:
'Step7 V5.3 Service Pack'
Thank You
Just realized the Siemens Step7 V5.3 Installation Disc I have has SP3 Included. I'm going to try to look for something more Current. Is it Possible to Xfer the License from one Laptop(#3) to another Laptop (#2)? The Licenses are on Floppy and this is causing a Degree of Difficulty.Laptop #2's Trial License just Expired. I have 4 Floppy's with what I Believe are Current Licenses but no Floppy Drive In Sight!Siemens has Instructed me to Send Them the Floppy's & they'll Xfer the License to USB ThumbDrive. This is what I'll be doing Next, But I still need Laptop #3 Working.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
137
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
525
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
541
