Step7 NetPro -opening project problem
sinuhe
Nov 2010
Warsaw
I have a problem and i can't resolve it.
I want to configure some connection beetween plc's,hmi's etc but whenever I try tu run the NetPro using icon in toolbar or net icon in Simatic Menager [MPI(1), Ethernet(1), Profibus(1)] i get the message:
Network open (2263:9)
Unable to project 'xyz'
Another application might be processing it.
Of course the all the project files are closed.
Another symptomps:
1. If I try to run the "Connections" from the CPU panel i get the same message but with the next:
Open Object (256:26)
An OLE error occured.
2. When I try to open the properties tab of the existing network's they open only in "read only" mode.
Any ideas? All the methods with use of "reorganization" failed.
Ok. I'll try. But other strange thing is that, that on another computer with STEP7 the messages are the same. So I think it's problem within my project.
I got the same error.
I managed to clear the error by creating an empty STEP7 project, then simply copy-paste everything in the Simatic Manager from the defective project to the new (all stations and all networks).
It really worked well. Just ctrl-n,ctrl-c,ctrl-v and all your problems are gone. Magic!
Thanks a lot once more time!
If I change the hardware configuration of a Simatic S7-400 PLC and perform a download in order to add new slaves to the profbus, does this...
4,400
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
41
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
148
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
174
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
159
