Step7 - Problems with FC5 - DI-STRNG
Oops!!!
Silly question, have you loaded FC5 into the PLC and is the software fault OB loaded?
You beat by 1 minute!
I'd forgotten that on this one station I'd loaded OB121 to cover up another problem that I hadn't got to the bottom of!
It's the simple ones that get you!
Cheers
Roy
Hi all, I will try and give as much info as possible to begin with but I am a graduate thrown in at the deep end so bear with me please. Upon...
5,303
Hi Im trying to use SFC20 BLK Move in a piece of SCL code in Step7. I need to copy/move one string[16] in a DB to another DB place ! If a block...
13,507
Would anybody like to have a look at the attatched source file and see if they can come up with a suggestion for what's wrong with it. Initially...
5,222
Can somebody have a look at the appended code. I think I've got to the point where I'm seeing what I expect to see instead of what's really there...
5,372
I've got a production line station which has two Cognex cameras in it to check that components are present and correctly orientated. The second...
3,964
