Step7 Step Sequencer Questions
Jul 2007
Kiruna
600
Hi All,
I've been doing a little reading here on Step Sequencers-State Machines before I begin to implement a rather lenghtly one for a project before me.
The sequences are not complex only requiring a number of activations of valves, pumps etc when certain conditions are met. They could be however 50 steps in sequence.
http://www.plctalk.net/qanda/showthread.php?t=45009&highlight=step+sequencer+S7&page=2
I've been reading this thread with interest and decided to run with Manglemenders example of using an input Word and an output word to ensure each step remains active for at least one scan. This makes sense and I have to admit in some smaller projects throughout the years I may have not considered this. I've always opted to use a single Word for step status and evalulated this on each rung as a permissive for activations.
Now on to my questions...
1. I need to have a timer (watch dog of some sort) running during each step. If possible I would like to use a single timer and change its preset after each transition. This will be used to either step on or fault the sequence.
How can I detect that the sequence has stepped on using the logic (FC21) posted in above link.
2. The client has requested the ability to Hold/StepOn/StepBack the sequence. Is this possible to implement this using this logic?
Please ignore my first question...
To detect a change of state I was comparing the Input Word to Output Word and if they were not equal then the timer would reset. It wouldnt work but the rung should have been before the last rung were I copy the Outputword into the input word!
I am experienced with many PLC platforms except Siemens. Now I must learn Siemens for my new job. My employer has relied on the OEM for PLC...
21
9,109
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
142
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
132
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
523
