Step7 to SEW MoviPLC
Ranjith
May 2007
Melbourne
316
I need some help on Siemens Step7 to a SEW MoviPLC. I need to know the status of MoviPLC from step 7. When I asked the question from SEW they said that I have to use Parameter channel from Profibus master. If there is someone with parameter channel experience pl help me.
Hi Ranjith.
I dont know everything about this, but I guess you have a SEW drive on Profibus with the socalled ProfiDrive profile. "Profidrive" is another way of saying it uses the PPO mechanism for transferring data.
PPO is split into two parts, PZD for cyclically transmitted data (normally commands and status) data, and PKW for asyclically transmitted data (mormally parameters). Try to search for "ProfiDrive" on Siemens and SEWs websites to find out exactly how these match each other.
There are some members who knows more.
You can also look for how Siemens MicroMaster drives use the PPO/ProfiDrive. The method is similar, but the parameters are different for SEW and MicroMaster.
As usual flicked thru the pages of MoviPLC manual and all the info was there.
Well, that gets my vote as the outright worst response ever to someone's attempt to help.:mad:
Jesper spends years accumulating the knowledge to answer this question, a few minutes reading your post and writing an answer, and you then dismiss it all by saying "as usual it was all in the manual". Grrrr...!!!
So other people's time on this forum is worth so little to you that you don't even RTFM first!
Ken
Hi All. First time poster here. I have a requirement to control a SEW Movidrive Compact 'Table' or 'Bus' positioning using STEP7. (Via sbus and...
4,562
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
80
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
191
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
182
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
163
