Step7 v5.2
S7 ver 5.2
I have installed S7 ver 5.2 with SP1 on my home computer running XP home edition.
So far I have had no problems, this does not mean I will not have problems with it though!!
Hi Martin,
Yes you can run Step 7 v5.2 without any problems under win XP booth professional and home edition. There is also an update to Service pack 1 available at siemens supportpage. Free of charge.
Rudi
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
85
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
194
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
183
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
164
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
164
