Step7
Gromit
Jun 2006
119
Hello,
Could you please tell me the difference between the two Step7 licenses:
1. SIMATIC S7, STEP7 V5.4, RENTAL LICENSE FOR 50 HOURS, E-SW, SW AND DOCU. ON CD, LICENSE KEY ON FD, CLASS A, 5 LANGUAGES (G,E,F,I,S), EXECUTABLE UNDER WIN2000PROF/XPPROF, REFERENCE-HW: S7-300/400, C7
2. SIMATIC S7, STEP7 V5.4, DATA MEDIUM INCL. TRIAL LICENSE FOR 14 DAYS, E-SW, SW AND DOCU. ON CD, LICENSE KEY ON CD, CLASS A, 5 LANGUAGES (G,E,F,I,S), EXECUTABLE UNDER WIN2000PROF/XPPROF, REFERENCE-HW: S7-300/400, C7
Bear in mind that option 1 costs 10 times more than option 2 ?!?
Thanks in regards
Item 1- is used for maintenance personel- Every time the software is opened the clock starts. Close the software the clock stops.
Item 2- is used as a demo package, when the software is installed and opened a 14 day trial is activated. The 14 days is all you get.
Maybe someone else can add to this
The 14-day licence comes on the same diskette as the full license; I don't think you can buy it as a seperate package. It is a backup solution if you lose your full-license authorization, and once installed it runs out in 14 days (whether you use it or not, whether you uninstall it or not). You have to have it re-authorized (and the day count upgraded) at the same time you request the re-authorization of the full license. With the 14-day license you can still operate your authorized software while you are waiting for Siremens to contact you for re-authorization (they are very helpful by the way, had to do that exact procedure with my PDM software last month).
Hope this helps,
Daniel Chartier
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
67
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
177
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
180
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
162
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
162
