G'day Gents,
Been given an opportunity to play with Logix designer and a Compactlogix controller to learn a bit more about Ethernet/IP CIP devices. Normally play with Micrologix PLC's so steep learning curve.
Playing with some EDS files and some AOI from Phoenix Contact
https://www.phoenixcontact.com/online/portal/au/?uri=pxc-oc-itemdetailid=2907074&library=auen&pcck=P-22-07-07-01-01&tab=1&selectedCategory=ALL
Was a walk in the park. Added the module, inserted the AOI rung to read the data from the UPS module, configure the IP address and away she goes. All too easy.
Now if I wanted to add a second rung with the same AOI for a second UPS module, I assume that it would overwrite the variables from the first rung.
Is there a way to duplicate an AOI to make a unique set of variables?
