STL - Boolean pointer looping
davidsk2001
Jun 2006
Bukit Mertajam
Hi all, i'm working with STL code following case.
STL will continuously loop to check the condition of an array of boolean (Array[0..99] of Boolean). It will detect boolean is ON or OFF only. If condition is ON, then run a timer; if condition is OFF, then loop the pointer.
1. How do I check boolean value with pointer?
2. How do I restart pointer once it reach 99?
Thank you so much for helping me out
Siemens Step 7.
I had manage to get this. But I can't get access status from my array of boolean.
L P#DBX 0.0
LAR1
L MW 2 //Check pointer below 100
L 100
>=I
JC ST02
A [AR1,P#0.0]
L S5T#2S
SD T 1
JNB ST01
A T 1
JNB ST02
L MW 2
L 1
+I
T MW 2
+AR1
ST01: L MW 2
L 1
+I
T MW 2
+AR1
ST02: NOP 0
Step 7 is just the brand name for the Siemens PLC programming package. It comes in two flavors: V13/TIA Portal or v5.5/Simatic Manager.
Sorry. it is simatic manager V5.5.
i don't know the answer,only question
if the few bool [ ] is ON what happen to the timer ON
If few bool[] is on, then it will run the delay timer and jump next bool[n+1] once delay timer is reach.
if bool[] is off, then it will skip the delay timer and jump next bool[n+1]
You need to be more specific - what exactly is a "few"?
if bool [3] is ON and bool[4] is ON and bool[6] is ON timer starting/complete ,then jump to bool[5] and bool[7] ?
what will happen if previous bool repeat the process ?
what source triggering the bool ,are the triggering step by step or randomly.
For example:
bool[3] is ON, bool[4] is ON, bool[5] is OFF.
when detect bool[0] = OFF, pointer will go to bool[1] without delay timer.
it will run until bool[3] where is ON. then bool[3] will wait for delay timer to complete and go to bool[4]. bool[4] = ON, then it will also wait for delay timer to complete and go to bool[5]. bool[5] = OFF, then skip delay timer and go to bool[6] and go on.
it will keep on looping the array until bool[] go OFF.
The source trigger the bool will be trigger randomly by external code.
For example:
Code your application completely for 3 bools, and post the code as an archived library. We can then see how to expand it for 100 bools
For example:
What about drawing a good, old flowchart? With a pencil.
Kalle
Kalle
Thank for the suggestion. Hereby I attach the flow chart for the whole idea. Hope everyone can understand for more.
Hello, I am new to PLC programming. I have a very basic doubt about STL programming. As per Siemens manual 'Statement List (STL) for S7-300 and...
2,314
i am new to simatic manager and i am trying to figure what this part do in the code : A I 5.6 = DB50.DBX 4.6...
136
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
210
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
324
First off thank you in advance. Second I am very new to STL. I am trying to build a counter that has one count up and 23 count down options. Am...
380
