stl question siemens s7-400
risbo213
Dec 2014
skopje
Hallo
Can you help me with understanding of the code below:
M001: NOP 0
L #PUNTATORE
L 16
*D
LAR1
OPN "ISTROGRAMMA"
L DBW [AR1,P#0.0]
T DBW [AR1,P#2.0]
L DBW [AR1,P#100.0]
T DBW [AR1,P#102.0]
L #PUNTATORE
L 1
-D
T #PUNTATORE
L 0
>=D
JC M001
Regards
Riste
It's a loop.
Code:
      M001: NOP   0
      L     #PUNTATORE
      L     16
      *D
      LAR1  //calculate address offset
      OPN   "ISTROGRAMMA"
      L     DBW [AR1,P#0.0] //load word from block ISTROGRAMMA with previuosly calculated offset
      T     DBW [AR1,P#2.0]
      L     DBW [AR1,P#100.0]// same as above just add 100.0 offset to calculated
      T     DBW [AR1,P#102.0]
      L     #PUNTATORE
      L     1
      -D
      T     #PUNTATORE //subtract 1 from var PUNTATORE
      L     0
      >=D
      JC    M001 //jump to M001 if PUNATORE > or = 0
I'm having trouble trying to convert this code to ladder, anyone able to help me? A M4.0 A M4.1 A M117.0 AN M17.7 A ( A I38.6 AN I3.7 O ( A M4.5...
1,210
I have an FB that had about 30 rungs of LAD code. I switched views (ctrl+2) to add some additional networks and create some STL code. Now, when...
3,527
program : L #measurement + -1 SLD 4 LAR1 AUF "DB72" L DBW [ar1,P#4.0] question1 : measurment =5 5-1=4 0000 0000 0000 1000 SLD 4 gives 0000 0000...
14,374
Hi all, I'm new to Siemens (I feel like a lot of threads start like this) and I'm trying to write a bit of code in STL. Currently we have a...
1,278
O m0.0 O m0.1 A m0.2 = m0.3 Is the m0.2 "and'd" only with the m0.1 or is it "and'd" with m0.1 and m0.2 (which are or'd)? -{}-----|--()...
1,705
