stl to ladder conversion in s7-300 and s7-400
macahael
Jan 2009
turkey
I want to convert program written in stl to ladder.Sometimes it is failing as the programmer do not write nop statement in code.İs there a program ( freeware preferably ) that convert stl to ladder.
I search google for this conversation issue, only thing that ı grasp is to add NOP for every terminal that is not used at ladder, for example
we have an up counter which have ladder representatiın at attached figure
ladder do not have any connection at 5 port , so we should have 5 nop ,
A I 0.5
CU C 1
BLD 101
NOP 0
NOP 0
NOP 0
NOP 0
NOP 0
A C 1
= Q 4.6
Are there any other rules for converting STL to Ladder.İf anyone have systematic information, can you help me ?
Cagrı
Hi
Dont know about rule but one longer way would be:
If suppose u have used timer in STL, then see how many NOP are required in case of timers (First by making timer in Ladder and then switching to STL) like this make chart for all the other symbols and then implement in your conversion.
If success paste the chart over here :D
re
Let me explain the issue more clearly, C is counter in stl , ı do not specify any s, pv, r input and ı do not specify any cv and cv_bcd output , all of unspecified input and paremeter number is 5 so ı add 5 nop commands when converting from stl to ladder..
There are many other rules for stl to lad.
eg.
A(
0(
you need to ensure that And open & close brackets are correct.
some programmers also make segments too long i.e. instead of only having one output in a segment they do loads of logic that will not translate.
in this case insert a BLD255 where you need a segment end & when in ladder will convert.
Hello guys. I need some help trying to rewrite some STL code into Ladder so i can try to understand whats going on. I struggle to watch the RLO...
6,534
BLD 103 is from the conversion. = L 4.1, also this, it's first writing to locals ??? why ? Is it possible to write like this: CALL...
4,178
Hi everbody I know only ladder programming in S7 200 and S7 300; but during analysis of STL code I face lot of problems. Can anybody help me to...
10,915
Hi, Anyone know why this network is not longer shown in LAD format but only in STL ? O "RB 20878".EinfV O "RB 20878".EinfR...
2,540
Hi people, could any one tell me if i have converted this STL code correctly A M 30.7 O M 31.0 A M 105.7...
1,472
