stop
romenger
Jun 2013
Cachoeirinha
Hello,
I have a clp s7-300 (317-2fk14-0ab0) with security system installed in PROFINET this going to stop. diagnostic messages are as follows:
Stop caused by stop command
Data corrupition in safety program
clp occur several stops per shift of production, we are using the Drive SEW MOVIFIT with safety channels and we are in doubt whether it can be putting in the stop clp ...
Since I'm already grateful for the help ...
Where is/are the F-call(s) in the program? OB1 or timed interrupt. Is there more than one timed interrupt? What does the online view from safety integrated show?
The Passivated I/O message indicates that the CPU has detected an error in the I/O which could be loss of comms or a channel fault.
The area length error is also a concern. Is an indirect address calculation producing incorrect anypointers?
Nick
See I compile the program and returned me two errors that would look like the standar writing program accesses the F-block program, but not always strike to stop the cpu
The code is in a fb281 and writes an f-block like this:
** The "VKE0"
****** = "F00515_F_Module_I_O__2_B". ACK_NEC
* The "VKE0"
****** = "F00531_F_Module_I_O__2_B". ACK_NEC
I found something about this kind of syntax error in program siemens forum
* I will test in a bit and post again if successful.
I did not have so far any more stop in clp will monitor some more time to think I've solved the problem.
however still has a message:
Event 1 of 10: Event ID 16# 2522
Area Length error when reading
Global DB, double-word access, Access address: 94
Requested OB: Programming error OB(OB121)
Priority class: 1
Internal error, Incoming event
10:23:08,075 PM 11/28/2013
(Coding: 16# 2522 0179 0034 005E 0000 0000)
how do I read this last code written in the end?
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
351
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
97
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
317
Hi everyone, I've got some trouble lately with a client and his communication with the server. I'm a beginner, and the project was not orginally...
94
Hi First post here! I admit I am not too used to handle interrupt OBs in Siemens. I have a customer who has been buying a standardized solution...
255
