storing data from B&R PLC through ethernet to PC
nickygriff
Sep 2014
Hampshire
Hi guys,
I've been using a memory stick to store errors generated on my software by using device link. That works fine, but I would like to store the data directly to a network drive, or even the desktop of the connected laptop.. I've tried devlink and failed, does this need to be done with the AsEth libraries, or am i doing the devlink wrong? If anyone has any examples or info it would be much appreciated.
You can add a network share (CIFS) with devlink. If you are having issues, it is normally on the Windows side. I usually ended up adding a user to the Windows machine named BR_PLC and giving it a password because it was easier than figuring out how to make an unprotected share accept the devlink connection. If the computer is on a domain, the configuration gets a little strange. I don't have examples unfortunately, my B&R projects are all on a drive that needs data recover service!
You can also setup an SQL server and have the PLC make entries (AsDb). This sounds like a lot of work, but I eventually found it to be easier than getting the FileIO setup.
Hi Winky,
I knew that it couldn't just be me finding this so difficult! Time to do some research on SQL servers then I guess.
Thanks a bunch!
I have an AB L27ERM PLC and a Panelview Plus 1000 with a local network setup with a PC on the machiene. 1. What is the best method for exporting...
2,891
Hi All, I recently set up some controls for a new machine using an Omron CQM1H PLC. I have 30 memory locations with voltage data after the...
3,630
Hello, I have an int variable that updates the value every second. I want to store the 100 values in an array. Array should keep storing the...
1,018
hi, i made a program of controlling temperature of 20 tanks using PID control. now i want to store the data of the present temperature of the...
2,901
I'm on PLC 5000. So I'm trying to store mutiple things. And trying to find the shortest way to write it without using so many rungs. I'm using FFl...
1,416
