Suggestions for collecting and storing plc data
edman
May 2007
ohio
Hi All,
I recently set up some controls for a new machine using an Omron CQM1H PLC. I have 30 memory locations with voltage data after the process is complete, which are displayed on a touch panel. I need to get these values into an excel file for later review. I also have other memory locations with type numbers and names of the product being run that woud also need to be stored in the same file as the voltage data. I would then clear the memory locations in preperation for the next run, and store that data in the same file as the previous. I am looking to store a whole days worth of data in each excel file, and start a new file each day. I am pretty good with PLC programming, but not so much with data collection. What would be the best method of doing this? The PLC does not have ethernet, just Comm ports. Thanks in advance.
I know this topic has been brought up a few times, but i had some specific questions. I have installed several 1783-NATR devices and they have...
310
I'd like people's opinions on which manufacturer of hardware they prefer. We are an aerospace manufacturing facility that does little to no SCADA...
531
I am setting up control for Hypochlorite dosing. The easy part is the dosing calculation for flow pacing but I would also like to setup trimming...
948
I'm working on an application and have hit a bit of a snag. I need to find an industrial touchscreen display that can: - Tolerate down to -40C...
758
Hello Everyone, I am reaching out to this knowledgeable community with a peculiar problem I've been experiencing with a PLC 5/40E. This issue has...
2,279
