Hello!
I'm struggling with a puzzling issue that's sporadically preventing our VMs from connecting to the activations we've set up on the Host.
As a bit of background, I found an extremely helpful post (#5) from Ken in the following thread: http://www.plctalk.net/qanda/showthread.php?t=67308
I did my best to set up our machine in the same way. I have a Windows 10 Host with Workstation 12 Pro. I'm running a Windows 7 VM with one Bridged connection set to "Replicate physical network connection state" and one Host-Only connection with a static IP. FactoryTalk Activation Manager is configured to get activations from my Host-Only static IP on the 27000 port.
For the most part, this works great. My activations come through fine, and I can communicate with a PLC over the bridged connection. Here's the catch: As soon as I plug in an ethernet cable to connect to a PLC, FactoryTalk Activation Manager loses connection to the activation server.
I can eliminate this problem by disabling the windows firewall on the Host. I've reproduced this behavior a number of times and toggling the Host firewall off and on directly correlates with whether or not the ethernet connection interferes with the activation server connection.
My supposition is that FactoryTalk Activation Manager may be trying to go through the bridged connection for the activations when a cable is plugged in. It is apparently successful when Windows Firewall does not intervene. I'm not sure how to make the firewall allow this, or force the activations to go through one adapter versus the other.
I would prefer not to disable the firewall on all of our laptops. Has anyone else run into an issue like this, or have any suggestions? Thanks!
