Hello all,
I am facing an issue with my Commander SK that I cannot solve on my own, I am struggling on it since several days
The really basic setup to produce my problem is :
- Pr 05 set to Pad (keypad mode).
- Terminal B2 bridged to B4 to always Enable the drive.
- Pr 35 set on AtSpeed instead of the default ZeroSpeed.
This should normally set the Digital Output terminal (B3) to ON when drive is at asked speed. But, on a fresh power on, the output still behave like it is on "ZeroSpeed", so it's ON at idle and OFF as soon as drive start to spin.
If I simply press once the STOP/RESET button on the keypad, output start to work as intended (at speed) without issue. But, at next power off / power on of the VFD, it still bug.
ATM, each time I power up the machhine I have to press once the STOP/REST button for my VFD to behave as intented..
Anyone have a clue on what's my problem ?
Thank a lot.
Thank a lot.
