Strange Siemens 314C-2DP adressing problem
smf
Jun 2006
Växjö
71
Recently i encountered a very strange problem with a 314C-2DP cpu, the problem i have is with the internal inputs.
Right now i have this cpu on my desk without any other I/O modules and i have configured the inputs to start at adress 0.
But if i give it a input at for example I0.0 it shows up as input 2.0 when i monitor the inputs. I0.1 is I2.1 etc..
Only the first 8inputs is working (but with the wrong adress) i cant see the other 16 inputs when using the variable table.
I have been in contact with the siemens support but so far they have been unable to help me, the last time they gave me the advice to exchange the CPU so i did but the problem is the same with the new cpu!
I'm using step 7 V5.4 and i have been using this kind of cpu many times in the past without any problems, even my old hardware config that was used a few months ago failed.
The outputs & analog inputs is working fine btw. and i do not have this problem with other S7-300 cpu's
The first Byte (x11) of the 314C-2DP cpu is 2 (DI+2), the second(x12) is 0 (DI+0) and the third (x12)is 1 (DI+1).
Take a good look at the front of the CPU.
Hi all, We have a system that comprises of a Siemens HMI talking to 5 Siemens 300 series PLCs via MPI. The PLCs and the HMI are about 50m away...
2,972
Today I connected a new KT600 to a Siemens 317F safety PLC to display some basic information. This all worked fine and was connected via...
3,151
Hi all! On my system with a S7-319 and a couple of IM151 nodes I do not get the AO cards to work. The fault appears on all nodes... DI, DO, and...
2,707
Hello, I am using 331-7KB02-0AB0 AI 2X12 bit module. Input address are PEW 200 and PEW 202...Both are configured as 4-20mA. Now when going...
18
15,857
Hi everyone, I had a strange problem with TP 070 panel display yesterday. After I downloaded my project ( which has 4 screens) I noticed that in...
7,211
