Stratix Multi VLAN NAT
Fanu**72
Oct 2020
Cali
hello there,
so i have a stratix 5700, that i need to setup with some NATing. System is close to whats described in the plcguru link here https://www.*************/stratix-5700-nat-routing/
Question is can i get rid of the second switch and still expect this to work? i.e. if instead of configuring the nat translations on the second switch i added them to the switch that has routing enabled. and then obviously connect machine 20 & 21 into that switch, assigning all ports settings to the vlans correctly should i still be able to ping the controllers from the pc?
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
116
Kindly, if we enable the routing on the Rockwell Stratix 5700 switch, as in the below link, will it cause any trouble? Like for axis motion...
195
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
121
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
149
Hi Folks! Could I use the Studio 5000 to read/monitoring Stratix 5700 parameters? Like switch temperature for example
425
