String conversion RS-Logic
Oct 2008
Copenhagen
24
Hi
In the attempt to create my first RS-Logic program, I have met a small challenge, on how to cast/convert data.
I receive an array of 255 SINT from profibus. In this 255, I know that SINT[4] to SINT[24], is a 20 charater ASCII string.
My problem is, that I can’t find a instruction, that I can use to extract this as a string.
I have tried something like this without any luck.
Code:
BATCH_ID := "";
FOR Iterator := 4 to 24 DO
	CONCAT(BATCH_ID, MVI56PDPMV1.PROFIBUSData.Input[ Iterator ], BATCH_ID);
END_FOR;
Does anyone have a suggestion on how I can do this conversion ?
Use a COP or CPS instruction to move the 20 bytes into the .DATA[x] portion of a String tag.
COP
Source: MVI56PDPMV1.PROFIBUSData.Input[4]
Dest: MyString.Data[0]
Length: 20
Use a MOV instruction to move a constant of 20 into the .LEN argument of that String tag.
MOV
Source: 20
Destination: MyString.Len
Hi All, I am having trouble converting a real to string and keep it to 2 decimal places. I'm sure its a simple solution. Any help is appreciated
292
I am working on calculating a checksum value for a command that is to be sent from an Allen-Bradley CompactLogix PLC to a Mass flow controller...
4,331
I have a Cognex 8050 barcode scanner and I am trying to pull recipes from this information. The recipes are in different locations in the string...
19
3,743
hi, I am trying to convert a string value to int but it is not working and I cannot figure out why. I have a string which is constantly...
10,202
Hello All Im using a FESTO PLC with Codesys. I have a string, named "Program1", which Im trying to convert to a datatype of Word. Im not...
12,509
