String initialization (Step7, STL)
Supreame
Jul 2008
Brasov
33
Hello,
I want to do a very basic string initialization: each element of the string to be NULL (hex: 0x0).
I noticed that if I use the Initial Value in DBand I put there '' each element of the string will contain '' - the character space (hex: 0x20).
For example I have a string in DB1 defined like this:
Address, Name, Type, Initial value
+0.0, EmptyStr, STRING[30], ''
For initialization I use this commands:
L 0
T DB1.DBB 2
T DB1.DBB 3
T DB1.DBB 32
But this mode of string initialization is quite primitive.
I will like something as this C code:
i=2;
do
EmptyStr=0;
i++;
while(i<=32)
What is the STL equivalent for EmptyStr ?
In SCL you can write
MyDB.EmptyStr := '' ;
In STL, that translates to
L W#16#xx00
T DBn.DBW 0
Where "xx" is the length of the STRING in hex.
"n" is the DB number.
If you have defined a STRING[20] in DB1 as the 1st variable in the DB then it becomes
L W#16#1400
T DB1.DBW 0
edit: I assume that you interpret the STRING only as STRING. In that case it should be enough to set the length to zero, as I did.
If you somehow look at the individual CHARs in the STRING, then I think you have to clear them all as LD[] does.
Here's a zero string example:
Code for FC2:
Code:
FUNCTION FC 2 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  sString : POINTER ;
END_VAR
VAR_TEMP
  iDB : INT ;
  iCount : INT ;
END_VAR
BEGIN
NETWORK
TITLE =clear string
	  L	 P##sString;
	  LAR1  ;
	  L	 W [AR1,P#0.0];
	  T	 #iDB;
	  L	 D [AR1,P#2.0];
	  LAR1  ;
	  OPN   DB [#iDB];
	  L	 B [AR1,P#0.0];
Loop: T	 #iCount;
	  L	 0;
	  T	 B [AR1,P#2.0];
	  +AR1  P#1.0;
	  L	 #iCount;
	  LOOP  Loop;
END_FUNCTION
Thank you so much sir. Your knowledge is very useful for me.
Code for FC2:
Code:
TITLE =
VERSION : 0.1
VAR_INPUT
  sString : POINTER ;
END_VAR
VAR_TEMP
  iDB : INT ;
  iCount : INT ;
END_VAR
BEGIN
NETWORK
TITLE =clear string
	  L	 P##sString;
	  LAR1  ;
	  L	 W [AR1,P#0.0];
	  T	 #iDB;
	  L	 D [AR1,P#2.0];
	  LAR1  ;
	  OPN   DB [#iDB];
	  L	 B [AR1,P#0.0];
Loop: T	 #iCount;
	  L	 0;
	  T	 B [AR1,P#2.0];
	  +AR1  P#1.0;
	  L	 #iCount;
	  LOOP  Loop;
END_FUNCTION
Very helpful sir. Thanks a lot.
I'm using PanelBuilder32 (version 3.5, build 84) with a PV1000 HMI (2711-K10C9). Does anyone know how to include control characters in the...
2,063
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
250
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
173
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
141
