"Stripped-down" data for PView download?
DairyBoy
Jun 2007
UK
393
Hi All. I came across an unuseable PV upload the other day, but the site had the original version so I did the mods that they wanted, but come download time and panelbuilder told me that the file was too large for the terminal's memory, but if it was stripped of upload data, it would fit. Thing is, there didn't appear to be any info as to how this trick could be acheived. Would a memory card fitted to the PV allow for a greater sized project? There are a few PVs on this site and one has a card. This PV is configured to read from the card on power-up (I guess this also implies the same, following each fresh download) and so it keeps reverting to the old values. How do I save the current values to a resident card? Sorry it's a long one, just trying to cover it all in one hit. Thanks.
See Pic:
And PDF
The memory card is not going to increase the memory of your PV
When you download, I think you are given the option to send/not send upload information. If you don't send it, the app will still run, but cannot be uploaded later.
Other ways to shrink the application are: remove bitmaps, unused objects, unused tags, and unused text objects.
To remove bitmaps, go to File, Import/Export Graphics to see a list of currently loaded bitmaps. Only imported bitmaps can be deleted. Standard symbols will have the delete button greyed out.
Text objects are often left behind unused. Open the Text Editor and sort by count. Delete text items with a zero count.
In the tag editor, you have to select each tag one at a time and press SHIFT + CTRL + T (or use the right clikc menu) to find out if they're used.
Hope this helps...
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
56
Hi: For ControlLogix. Is there a way to "trap" when processor is powering down? This mean leave a bit latched or a value written to a tag? Is...
247
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
394
Hey guys, I got a carriage that can move with X and Y axe, each side got their own cylinder so left and right. It doesnt happen very often but...
330
Hello everyone! So basically I have this PF 525 that no matter what I do won’t let me speed down. It always shows 66.66 Hz and the parameters to...
1,194
