Structured Text Increment Integer
I have never seen a situation where the ladder code for an entire routine is objectively simpler than the equivalent structured text code. However, I regularly see situations where the structured text code is objectively simpler than the equivalent ladder. In fact, the compare and compute functions that most ladder editors provide is just a way to inject structured text to simplify situations that would otherwise be comically complex in ladder.
Take this thread's example. In ST, this is a simple if statement check for a falling edge by some means, then adding 1 if the if statement is true. Depending on the platform, you could use EDGENEG(), F_TRIG(), OSFI() (this is a falling edge one-shot in Studio5k), etc. I'll show EDGENEG() since it's an operator instead of a function and so simpler.
Code:
IF(EDGENEG(MachineState)) THEN
    DownCount:= DownCount + 1;
END_IF
More platforms would probably use F_TRIG() which adds one or two lines to call the F_TRIG and is functionally more identical to the typical ladder solution
Code:
MyFTrig.CLK:= MachineState;
MyFTrig();     //alternatively combine these two lines into MyFTrig(CLK:= MachineState);, but I think that's harder to look at
IF(MyFTrig.Q) THEN
END_IF
I suppose you could use a count up type function in ST too
Code:
MyCountUp.CLK:= MyFTrig.Q;
MyCountUp.pValue:= ADR(DownCount);
MyCountUp()
That could be compressed to this:
Code:
MyCountUp(MyCountUp.CLK:= MyFTrig.Q, MyCountUp.pValue:= ADR(DownCount));
In ladder, most would probably do this sort of thing:
Code:
MachineState      SomeRandomBit        DownCount
----]\[-------------[ONS]-----------------[CTU]---
Both ST and Ladder in this case are super simple and easy to understand. The ladder rung will probably take up 20% of your vertical screen space while the ST is 3 to 5 lines out of a typical 50 displayable would be about 10%. As soon as you start complicating things in the condition, ST starts winning out as the ladder takes more and more vertical space until a single rung won't even fit on your screen while the ST might balloon to 15 lines and still fit comfortably on the screen.
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
248
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
390
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
133
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
72
Good morning. I'm doing a rehab and I need to recycle some part of the old code that won't change and that I need. This is a calculation that...
22
1,371
