Studio 5000 installation error
sinanmoral
Apr 2020
Istanbul
52
Hello,
I have studio5000 and my computer is windows 7 professional.
When I try to install Studio5000 V33 to my laptop then I got this error message '' Error 28005.The factoryTalk activation licence import failed.Would you like to continue your installation'' I got this error message during installation progress %14.
Any idea How I can solve and complete the installation?
You can see the error picture at the attacment.
Thanks in advance
Best regards,
Tell it yes, continue. It should finish up, then you can get in contact with Rockwell Activation Support. That support is free, possible just your license is tied up on another system or you are using a license that is checked out from its server at the moment?
Thank you for your reply.
I have just installation file without activation.
So after installation done, I will use it for grace period of 7 days and then delete it.
Problem is still is ongoing.
As long as you have a valid license, give Rockwell a call once you have it installed, they can help fix activation issues without a techconnect contract. Activation support is free.
Every installation of RSLogix(5/500/5K)/Studio5K I always do not activate it during the installation.
Every time you open it then it will look for the activation and open, or give a popup and/or close if it can't find one. For some reason Studio5K will not open on a grace period license like RSLogix5/500/5K will.
Hello,
Thanks for your reply.
My problem is solved.
I upgraded windows 7 to windows 10 and then try to install again so the result is ok and working.
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
104
We are experiencing VM OS corruption after Studio 5000 installation. This has occurred for several VMs. Strangely enough, not every VM is...
1,412
How does one obtain and install Emulate for RS Studio 5000? Company has professional license and professional installed on VM. No emulate. I go...
5,828
After installing Studio 5000 Logix Designer 33.01.01 , we got some errors. See attached and below. Is it serious? Install failed (1)...
2,093
Microsoft Visual C++ 2019 Redistributable (x86) install failed. I already have 2015-2019 on my computer so I thnk this is why but dont know what...
5,714
