Studio 5000 .L5K Export/Import to clean up code
Dayvieboy
Jun 2013
San Francisco Bay Area
132
Curious if anybody has any documentation or input on what this exactly does
Many times when I have a problem it is one of the first things tech support recommends.
It's almost like asking "did you cycle the power"
They all have a bit different take on what it does & have no reference documents to back it up
It takes the Binary .ACD & converts to XML
then converts the XML back to Binary .ACD?
Which I could always dissect & compare, looking for an easier answer
It usually makes the file a bit smaller
But it does not tell what it stripped out or modified
Tech support says it cleans up AOP's & Modules issues,
But what does it reference to clean it up?
Any insight would be appreciated
Thanks!!!
The process corrects corrupted sections of the file. It is a recompile of the code by Studio 5000. Error checking is part of this process. There is no documentation that I can find. If you want to find what was changed I would create a new L5k from the recompiled project. Then open both the original L5K and the new in Notepad plus and compare them.
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
291
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
123
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
127
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
78
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
205
