RickR99 Member R Join Date Nov 2021 Location Connecticut Posts 2 Nov 11, 2021 #1 Has anyone used the "MAJ" motion command? I'm trying to move an injector in the reverse direction. I would appreciate some help. THanks.
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,606 Nov 11, 2021 #2 I think you would use a negative speed value. Edit: I haven't used one in a while, DarrylR reminded me that there is a direction tag. 0=Forward, 1=Reverse Last edited: Nov 11, 2021
DarrylR Member D Join Date Nov 2019 Location illinois Posts 162 Nov 11, 2021 #3 In Studio 5000 simply right click the axis in the motion group and select the motion direct option. Then select the MAJ instruction, set speed and direction.
Smeltz Member S Join Date May 2021 Location Ohio Posts 20 Nov 11, 2021 #4 As already mentioned, just set the Direction to 0 or 1 (Forward or Reverse) in the MAJ block.
chavak Member Join Date Jul 2002 Posts 750 Nov 11, 2021 #5 And don't forget to issue a MAS to stop the axis when you want to. It doesn't work like a traditional job button
RickR99 Member OP R Join Date Nov 2021 Location Connecticut Posts 2 Nov 16, 2021 #6 It works! Thanks for all the tips guys. I got it to work from your tips. You are the best!
