Studio 5000 - Power Monitor AOI Import Fails
rtgibson
May 2012
Barnsley
44
Can anybody help out with this...somebody has sent me the ZIP for the PowerMonitor_AOI_FP_1.1 and asked me to import it into a PLC program I'm doing (it's for a Control Logix) to get data from a 1408 power monitor.
When I do a rung import I get the following error in Studio 5000 (V32) and it fails to import: -
Preprocessing C:\EDS Files\PowerMonitorAOI_FP_1.1\PM_AOI_FP_1k_5k\PM1K_RungImport.L5X...
Reading data type: 'pm1k_all_data'
Reading data type: 'pm1k_livedata'
Reading data type: 'pm1k_minmaxdata'
Reading data type: 'PM_minmaxlog'
Reading add-on instruction: 'PM1Kdata'
Reading tag: 'PowMon01_AOI'
Reading tag: 'PowMon01_Data'
Reading tag: 'Powmon01_rdata'
Error: Line 2280: Error creating 'Tag[@Name="Powmon01_Rmsg"]' (Tag can only be created at the controller scope.).
RSLogix5000Content/Controller/Programs/Program[@Name="MainProgram"]/Tags/Tag[@Name="Powmon01_Rmsg"]
Import failed - 1 error(s), 0 warning(s) - No changes were made to the project
Nope - not for me, doesn't look like I get an option. I've just realised it's a custom written AOI so I wonder if that has anything to do with it (just trying to get in touch with the guys that wrote it).
That's not the dialogue box being referred to, after you hit 'open' there it will open the 'Import Configuration' dialogue.
You can see the scope of a tag being imported if you dig around there, but I don't see any way to change it.
The message the AOI is referencing is scoped to the program that the AOI is scoped, so this was was written with a 5x80 controller. You're importing into a 5370 controller project.
What you can do is perform the import in a 5380 project, relocated the message to the controller scope, export the AOI rung, and then import to your 5370 project.
It is item #518253 on the list of arbitrary BS distinctions/limitations imposed between these controller families. That and unsigned/signed data types at #1 drive me up a wall trying to maintain code compatibility.
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
294
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
123
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
127
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
78
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
205
