Studio 5000 UI
JPNoyola
Jul 2019
Nomad
So, I've started working on projects that are using Studio v30 and above. The UI has been changed and while most apparent changes are just aesthetic I really miss stuff like being able to switch through routine tabs with ctrl+pgup/dn and having ctrl+tab switch only between tags, xref, and the like.
Does anyone know if there is any way to change those hotkey mappings? Or the UI in general for that matter? As far as I know I can only change the editor window's colors.
yeah it sucks. its like they are trying to make a a formerly great package(logix 5k and studio 5k) into a terrible one(Proficy).
Wow! I know that Proficy ME has its shortcomings, but I really didn't consider it terrible! Used them both, and had my share of issues with both. All depends on what you are used to, I guess...
I use AHK To make my own keys. It works most of the times, and you can even set it up so it's eligible for non-fullscreen windows.
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
343
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
125
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
129
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
80
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
211
