Studio 5000 v21.00.04
Lovell
Feb 2013
Saskatchewan, Canada
120
I have several Studio 5000 (v20.00.00) projects that I developed on my laptop and have loaded on L33 and L36 controllers. They are working fine and I can connect /go online to them from my laptop. I setup a desktop pc with Studio 5000 (v20.00.04). I can go online with the controllers and see whats going on. it is using the customers licenses which is mini edition. My laptop is pro edition.
My issue is I setup Produced/consumed tags between the processors and so in the IO tree there is an icon for the processor. A right click on it gets you to its properties and so on. On my laptop this is fine. On the desktop pc it shows as a '?' and has no properties. I thought ok, I need and EDS file for this. cant upload from device - no option there. So I go to rockwell website and download eds files for L33 and L36 controllers. install.
still not showing. I think ah! it must need an AOP - so I search and download everything i can find with AOP and L3X controllers and install.
still not showing. So I reboot the pc.
still not showing. :unsure:
Anyone here with an answer? Tomorrow I will call Rockwell for help if I cannot figure this.
thanks
Solution
I found out the problem (me) with Rockwell's help. It turns out when I added the L33ER on ethernet for Produce/Consume I set the controller revision as a V30 controller even though in reality it was V21. This did not affect the ability to produce or consume - that all worked fine.
I was able to add them at V30 because I had Studio5000V21 and V30 installed on my machine. So when I installed v21 on the Desktop PC it did not know what the controllers were (too new). I tried registering L33er and L36ERM v30 EDS files but it did not fix the problem. I know I can fix it by doing offline edits and a download but this plant runs 24/7.
So my fix on the desktop pc will be to also install v30 and then the v21 program should show the controllers correctly.
Ran into this issue and took a while troubleshooting the compatibility, was not in the release notes that i could find. Anyways had just installed...
1,477
hi, I alredy have rslogix v20 and now i want to install studio 5000 v21 , the intall get to this step: and its not possible to check V at logix...
2,558
Hi all, I'm setting up a new field laptop and need Studio 5000 v21 and v29. Now I remember there were some issues with v21, something about...
7,548
Cant seem to find much info on Studio 5000 v21.011. What is the difference with v21.11??
17
35,785
I am having trouble installing v21.03. I currently have v19 and v20, installed no problem. I get an error message when the install wizard is...
1,930
