Studio 5000 Version 21 does not open.
Solomonjg
Aug 2017
Virginia
Good morning,
Studio 5000 Version 21 does not go past the initial flash screen. I am trying to open a sample program to get familiar.
I am not sure what to look for.
Try uninstalling, and reinstalling without any of the optional features. On v21, there was a bug with the Clock Update Utility and one of the others that caused that problem. Or from memory, if you install a newer version and DO install all the optional features, the faulty one should get upgraded and you should be good to go.
try running in administrator mode, usually it will give an error code if this is the problem sometimes this happens to me but i am running version 20.
Solomonjg said:
Studio 5000 Version 21 does not go past the initial flash screen...
What is the full software version (major.minor.sub minor eg: 21.00.00)? This can be found under Help/About, or similar.
This technote outlines most of what ASF is referring to...
518662 - Studio 5000 v21 and RSLogix5000 v20 stop responding after first reboot upon V21 install
Access Level: Everyone
If your current version is 21.00.00, then they recommend that you install version 21.00.01 (on a Tuesday of a Full Moon, after 2pm). Alternatively, I could loan you my lucky Leprechaun's Hat, or, after you reinstall v21.00.00, never reboot your workstation PC.
Regards,
George
Hi Everyone, I am facing an issue while installing the STUDIO 5000 in my windows 10 PC. During installation I am getting an error that " Error...
115
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
435
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
489
Hi, Im trying to install Studio 5000 V32. I've installed the previous version in order from v20 to v31. Whenever I run the setup file i got this...
1,451
Hi All, While building the offline project for CLX 5580 with 1756 Rack I/O, I noticed that there is a field for "Series" and "Version" for some...
715
