Studio 5000
Oct 2013
Iowa
17
I am using Studio 5000 and can't get the Emulator to work. I have the Virtual Backplane running in Linx and am writing to the Emulator controller. It won't establish communication with the controller though. I am sure it is something I am doing wrong, but I need some help please.
Slot zero is the emulator controller. It says it can't go online and a communications path is needed. I have Linx open at the same time too.
Have you started RSEmulate 5000 software:
If yes. Have you created the processor in the emulate chassis?
I don't have RS Emulate Software that I can tell. I think it is different in version 21. You just open Studio 5000 and pick the Emulator controller. I also don't think there is a virtual chassis.
To use the emulate controller you have to have RSEmulate 5000 software.
RSEmulate simulates the PLC.
You need Studio 5000 to program / monitor the PLC
You need RSLinx to talk to the PLC
You need either a real PLC or RSEmulate to talk to.
Where can I find the emulator software.
I have installed Studio 5000 professional but can't seem to find the emulator anywhere.
Am I just being dumb?
Cheers
Mark
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
219
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
378
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
129
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
132
