Studio 5k - Turning number of bits on in an array of arrays.
PeeLC
Oct 2018
Krypton
30
Hello PLCs.net!
I have a relatively large array of arrays, and I want to turn bits on in blocks(first 50/200, something like this.)
What is a function that can be used to turn bits on in bulk? I'm more used to more text based languages, this ladder stuff is kind of trippy.
I have around 400 bits, and don't want to turn them on by hand. Is there an easier way to do it?
Please let me know, thanks!
Thanks!
-PeeLC
Without knowing more about what you're doing I assume you should use loops and indirect addressing.
An array of arrays? Do you mean a 2D array? Then I believe the format for indirect addressing is Array[w, x].[y], which points to the yth bit of the xth element of the wth array.
Use Jmp and Lbl instructions to make loops.
If you prefer text languages, Structured Text is generally better for big array manipulation tasks like this.
Why ?
There is a FOR instruction which executes a subroutine file a specified number of times.
I avoid JMPs and LBLs like the plague, code becomes position dependent, you often can't see the corresponding JMP to a LBL and vice-versa, and there's always the potential for no "get-out clause", causing an infinite loop and faulting the processor on watchdog timeout.
Hi guys I have a question for you experience people. I have a tben l4 8IOL module set up on a machine from the oem , And want to add a iolink...
36
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
81
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
16
338
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
125
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
129
