stupid question about electrical, nothing relate to plc !
To prove that red wires are the coil wires check them with ohm meter, should be a low resistance (possibly below 200ohms). Then check resistance between green wire and one of the red wires, should be in the high mega ohm range.
Tom
I have some DC coils with two red wires and a green wire. Tom has it right. Ohm it both ways to see if there's a difference, if not don't worry. I do not believe the ground is necessary in all cases. In some cases, it is part of a connector to which multiple different coils connect and may be dead-ended in a 24VDC coil with a plastic shell, or connected to case with an 240VAC coil in an aluminum case depending on which coil you connect. In either case, its a green wire so just ground it and remove all doubt.
(after you ensure it's not in the coil circuit)...
Been working with PLCs for a couple of decades, but almost 100% DirectLogic. Have a customer who wanted me to make a couple of simple changes to a...
1,123
New to the EcoStruxure programming software (I'm an AutomationDirect guy) and I've been banging my head against the wall trying to figure out how...
1,023
I am developing FT View for the first time from scratch. I have looked in the manual over and over and I cant find what I am looking for. I need...
2,612
I'm kicking around revisiting an idea I had a few years back. I have very little programming experience, just from school a few years ago. I had...
1,910
I’m not a regular user of soft starts but the SMC Flex list the aux contacts can be set to “Normal”, what does normal mean? The manual doesn't say...
5,044
