Submersible xmtr
GregPLC
Oct 2002
Milwaukee, WI
342
Just an FYI, over the last year or so, we have installed several submersible pressure transmitters, to control/indicate level in certain applications.
It's a mode of instrumentation that I've only recently started using. I don't want to promote the manufacturer, but I can say we've been happy with the submersibles installed thus far. Anyone else use them? I'm using them in a couple sump level, brine tank level, and RO water level applications....What applications have other people used them in?
Greg
level probes
We use Amatec level probes a lot in the carpet and textile industry to measure the volume of the chemical or dye tanks.
I've had good luck with Keller PSI units in digesters and sewage wet wells - nasty applications. You just have to make sure that teh selected device has a membrane or diaphragm to isolate the sensing system from the process fluid. I prefer this device to ultrasonics because I've had better reliability.
I've had some bad luck with submersible probes in locations that are prone to lighting strikes nearby, even when using lightning protection. In these cases I have gone to ultrasonic level measurement with good success.
We use them in our wells to track draw downs hourly and also in our resevoir for automatic shut down of pumps at night. no more early morning calls and runs to the plant to shut off pumps! :D :D
We have two submersible waste pumps in a sump. Submittals for the pumps are 1hp, 1.5A@460VAC Motor, 91GPM, 50FT max. Long story short, the...
18
5,434
Hello: We use submersible pressure sensor in oil tanks to monitor the level in the tank. We also have a routine the will estimate the oil...
1,403
A precipitous drop in the house water pressure sent me to check the pressure on the bladder tank - only 20 psi on system with a pressure switch...
5,107
Good day all, How does one go about scaling a pressure transmitter that indicates both Vacuum and pressure? The transmitter I have has a range of...
1,610
Hello, I'm working with a 1747-NI4 analog input module (for the first time) on a SLC503 processor. I noticed in the IO configuration within...
4,771
