Dear Members,
I am new to the PLC field. I am mainly working on microcontroller based embedded systems. I have implemented a distributed control system for an industrial laser with networked microcontrollers (8051) through RS485 serial link. Here various analog and digital I/Os are implemented on separate microcontroller circuits. All these microcontrollers (processing nodes) are coordinated by an industrial PC running Labview.
In this project I have faced lot of problem in rectifying EMI. I heard that PLC's are available for this type of implementation. I need guidance from PLC experts weather I can implement similar kind of system using PLC. My requirement is
16 Channel Digital Input Module - 24VDC
16 Channel Digital Output Module - 24VDC
16 Channel Analog Input Module(16bit) (4-20mA)
2 Channel Analog output Module(16bit) (4-20mA )
1 Channel Pulse output (1Hz to 10kHZ, 10 to 90% dutycycle)
Labview based (or similar) operator interface using a HMI or industrial PC. Kindly suggest a PLC for me.
Thanks and Regards
Itp
Thanks and Regards
Itp
