Survey document for automation system
PLC survey
____ Plant has On-site and Off-site copies of Control system files.
____ Plant has active backup Standard or Program that all Technicians/Engineers understand.
____ Plant Technicians/Engineers verify accurate backups against running programs every time they are performing work on plant Control Systems.
____ I know which Plant Control Systems I am responsible for.
____ I have identified the critical components of the Plant Control Systems I am responsible for.
____ I have verified Critical components are in stock on-site for Plant Control Systems I am responsible for.
____ Should any of the Plant Control system HARDWARE fail today, I know where to get the needed replacement to get back up and running.
____ Should any Plant Control System SOFTWARE fail today, I know where to get the needed replacements to get back up and running.
____ Should any Plant Control System COMMUNICATIONS fail, I know where to get the needed replacement Hardware/Software.
____ Should any Plant Control System I/O card fail, I know where to get a needed replacement.
more question for PLC survey
Collected Information
Machine or Area Name
PLC Program Name
Network Node Address
Network Name
PLC Brand
PLC Model Number
Is Spare Available
Date Program Last Backed Up
Discriptored Copy of program available
Does PLC have EEPROM
Last date Program Changed
Last date EEPROM Burned
Date battery last changed
Other information you may need
I hope you folks can provide me with some ideas and suggestions on how to manage your programming laptops while still keep in line with your...
24
5,039
I am interested in how many of you use IO-Link. I would like to know what the application is Your view of the availability of products. Ease of...
2,117
1732 ArmorBlock I/O has been around for quite a while and seems like a great way to distribute I/O. On a recent job, where I spec'd out...
2,804
Hello, #1 What HMI feature do you consider a must in an HMI? #2 What feature would you like to see in an HMI? #3 What is the most important...
18
4,308
Hi everyone, long-time reader of the forum, first-time poster. I have a customer that we've built a number of machines for that would like to do...
3,345
