Switch works, NOT!
what is the resistance of your meter leads?
0.5 Ohm is either Lead resistance or a faulty switch
hard wire - on a bench - 24v supply through the switch to a relay
BEWARE OF THIS - IF IT IS AN INTRINSICALLY SAFE DEVICE AS TOM ASKED
these units use less than 8 volts and need a barrier control
Ok. I tried pretty much everything between 5600 and 220 ohm and nothing worked. Switch shows always on. GEMS is about to become my friend.
There are physical contacts in the reed switch in the tube, and a magnet in the ball. Even if you
could get it to work using resistors, it will be unreliable, and not the right thing to do.
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
290
Hello everyone Iam working on washing machine which washing onion and water level is very critical for the process. The machine used IFM 121 for...
141
481
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
233
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
121
