Switching languages on a PanelView Plus 400
primeline77
Jan 2013
Arkansas
Hello all. I've just been handed a PanelView Plus 400 This mornng that has an application loaded in memory which is in a language other than English. I've been asked to get it to English. Has anyone done this and if so what is the fastest route in doing so? Thank you!
Hi
I have not done it on a 400 but only on a 1000 but I sure it's the same.
I also went from English to another language.
If the 400 is greater than ver 5 you can upload from the screen and open it. You then have to export it to a csv file and give it to some one to translate.
You can then import this and now you can change between each language.
I don't think this is what you want to hear but re view me will not translate it for you it will only hold them and allow you to change between them.
As always I am open to someone here knowing more or a better way than mine
Donnchadh
If you only want to English, the easiest way is to edit it to English on each buttons, message, alarms etc and load it back to PV Plus
But if you want to switch between different languages, you need to setup language switching. It is in the user manual. Attached is chapter 12
Regards
Hello guys, please let me ask if you have experience the same situation like this. Inputs are steady but the outputs OTE are switching off and on...
345
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
933
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
755
Hello, I have a Ge Fanuc 90-30 system with a Cutler Hammer PM 3000 Power series HMI. Besides the HMI, the customer is happy with the controls side...
1,021
I'm working with a ROC800 program offline right now. Normally, you can switch your TLP view between text and numbers by making your choice under...
859
