Symax 400 error and programming question.
GilovanJoe
Dec 2007
NE Alabama
I want to use register 8107 of a Sy/Max 400 to point to an error register stack but not sure how to program the rung to reserve this 16 register block. Would I need to use a shift SHFT or FIFO statement or use a sequencer function? The manual only states that I need to reserve this 16 register block, beginning before register 3985, exclusively for the Error Register Block.
While I'm OK with basic ladder logic, I'm not really familiar with the shifting of registers and sequencing. Like a lot of maintenance departments, I'm let with an older machine and controls and all outside support has ceased to exist. Don't really need to reprogram, just maintain it, and this error stack could help if I can figure out how to add it.
Using SFW-374 and DOS on an old laptop if this matters.
First question, is there any easy way to convert the symax logic onto the controllogix? I believe we have an old laptop that will connect to the...
2,336
Hello all, newbie here and looking for some advice on an old symax 400 plc. Had to set up a win xp machine with intouch wonderware connected to...
1,781
My Symax controller is reporting an offset from the measurement devices that are connected to it. This is only happening on one I/O module on all...
1,590
We have a demineralizer running on a Symax 400 PLC. The PLC is connected to a Cincinatti Display serially. This system is a late 80's early 90's...
2,475
I am unable to load a ladder logic project into this Symax 400. It begins to rack address and then I receive a transmission error 74 after about...
2,273
