Symbols change to absolutes against my will
Aug 2012
Tre
I have seen conversation about this somewhere but can't seem to find it...
I have a DB that has array of UTDs. Now when I had to insert a new element to the UDT, my STL code decided to stick into old addresses. Like,
CALL "ANY_ANY_SB"
any1 :="DBStor1".Slot[2]
any2 :="DBStor1".Slot[1]
RET_VAL:=#Slot_size
turned into
CALL "ANY_ANY_SB"
any1 :=P#DB101.DBX58.0
any2 :=P#DB101.DBX24.0
RET_VAL:=#Slot_size
Sometimes this would be nice, but in this case it broke the functionality of calculating size of one element of array. Is there a way to set certain FCs to rely on symbols when some on absolute, or is there only a system wide setting(which I currently can't seem to find)?
My ANY_ANY_SB can be found here, for free :) http://pastebin.com/2BAyNrvp
You have set "symbolic adress priority" ?
If so, after changing a base UDT from which other UDTs or DBs or FBs are derived, run a block consistency check. That will sort things out.
Thanks, that was it, explained in "Setting the Address Priority" chapter in help of Simatic manager. And it was in absolute / Step7<5.2 mode, changed to symbolic for all addresses, now "check and update accesses" works nicely without breaking the code.
182
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
146
I'm a bit confused about how symbols and UDTs work... As far as I know, in offline mode FB gets symbols from the UDT declared in the "state"...
432
I have a machine that was powered off for repairs, when powered back on the Panelview fails to upload the tag database from the PLC. Its a...
1,556
Looking for some explanation/history between North American electrical symbols standards (how they relate, what are the latest, what is the...
1,731
