Synchronising of PLC clocks
balihai
Sep 2003
Can someone suggest ways of synchronising PLC clocks? We are using a datalogger to log info from 4 different PLC's, hence the importance.
Thanks.
I agree with rdrast. Let the datalogger keep track of time.
If you choose not to let the datalogger handle timestamping, then pick one of the PLCs as the master. Wire an output from that PLC to an input on each of the other three. At some predetermined time (once a day, once an hour, you decide) as determined by the master PLC's RTC, have the master PLC turn on the output. When the other three PLCs see the corresponding input, they set their clocks to match the master's clock.
For example, every hour at 15 minutes and 15 seconds past the hour, the master PLC briefly turns on the output. The other PLCs see the signal and set their clock's seconds value to 15.
If the time sync is a must which in some cases it is. Steve has is on the right path, although, I would eliminate the hard wire and use internal bits for the sync process. Also you can just read/rite the clock values to/from the other PLC's if a predetermined periodic update will not work for you application.
Hello, I have a FactoryTalk Historian where I've configured some tags to record a couple of signals. This bit works as I check the historical...
1,702
I need to synchronise time of hmi with microcontroller 830.. i have been able to sync microcontroller time with PC.... using connect work bench...
1,477
Hi All, I am at the design stage of this one and looking for some pointers please ? Has anyone done anything to "synchronise" product flow on two...
25
10,629
Hi I am using ABB AC450 controllers with xA800 HMI.I observed that the time for the events and the trends are not matching .How can i synchronise...
1,210
Does anybody knows that is automatic synchronising system of Siemens company?(including software according to status of loads,some of generators...
1,289
