Syncing Two Motion Axis
bodoo23
Jan 2018
Athens
57
I geared two axis in studio 5000. The drives are kinetix 5700. My question is that if starting actual position of two axis are same they both work fine with gearing but if one of the axis is a bit slipped somehow before gearing , the gearing always keeps this difference.
For example if both are 75mm and I jog them they both go 90mm. That is fine
but if one is at 80 an the other is 75 before gearing. Final positions are 95 & 90 but I want them to be same like 95 & 95.
Is there any built-in command in gearing for this or Should I do it in plc program by myself ?
Thanks,
If you need the axes to travel different distances, you should probably command them independently instead of gearing them together.
Or, you could calculate the difference and gear them with a ratio: if Axis 1 has to go 15mm and Axis 2 has to go 20mm, you could gear Axis 2 to Axis 1 at a ratio of 20:15 = 1.3333.
Ideally, post more about the mechanical relationship and linkage between the two axes.
I wish this site would support LaTeX. It is easy. Our site does. Anyway
Assuming both axes are stopped then
v=1.5*Δx/Δt
a=4.5*Δx/Δt2
If Δt is constant for both axes they will get to their destinations at the same time.
this is easy.
It is much harder if the axes are already moving. I have solutions for that too. This is necessary for 3 and 4 knee carriages in saw mills. I had this worked out in 1986 but my current solution is much smoother given all the processing power available now.
You can perform an axis specific move on a geared axis. If you know ahead of time that they are not both in the same location, move one of them to the location of the other then gear them. Or you can gear them and them perform a MAM on the slave axis to adjust it to the master axis. You could even perform the move while the geared move is active. A lot depends on what your system can handle.
Keith
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,759
Dear Experts, I need a little help with a project that involves an Omron Vision used for quality control of cylindrical products (arranged in 2...
4,059
I have a project including two parallel conveyors carrying a wide material. There is no mechanical gearing. I have two powerflex 755 controlling...
4,178
Hello All, I know this has been covered probably 100 times but I am having issues with syncing my PLC time with PV. I want PV to copy the time...
1,889
I have a kinetics 6000 and a kinetics 6500 runing 2 different conveyors and ineed to sync there pockects over ethernet. Is there a simple way to...
2,559
