Syncing CompactLogix time with Panel view 1000
ersanjit
Sep 2018
Windsor, ON
Hello All,
I know this has been covered probably 100 times but I am having issues with syncing my PLC time with PV. I want PV to copy the time from PLC every 60 sec. For that I have used Wall clock GSV instruction and have configured those tags in Factorytalk View ME at Global Connections > Remote Day or Hour Fields.
Even after that I am unable to achieve this. Is there something else that I am missing?
Currently our PLCs are syncing time from one of our VM which I setup as NTP server. Now I want Panel Views to sync with PLCs as well so that we have a universal time in our plant. Please advice!
Are you triggering the Remote Date And Time in the PV Global Connection?
It is right above Remote Year.
Closing Thread
I found my mistake, it was in front of me. I was not using Remote_Date_Time tag as trigger (When it changes from 0 to 1, it triggers the update)
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,741
Dear Experts, I need a little help with a project that involves an Omron Vision used for quality control of cylindrical products (arranged in 2...
4,043
I geared two axis in studio 5000. The drives are kinetix 5700. My question is that if starting actual position of two axis are same they both work...
2,354
I have a project including two parallel conveyors carrying a wide material. There is no mechanical gearing. I have two powerflex 755 controlling...
4,175
I have a kinetics 6000 and a kinetics 6500 runing 2 different conveyors and ineed to sync there pockects over ethernet. Is there a simple way to...
2,556
