system clock in S5 115U with CPU 943
Greet
Aug 2003
Mol
58
I read the system-time and date in a S5 115U (CPU 943-7UB21).
That works perfect.
Now I want to do the same in a CPU 943-7UA21 or a CPU 943-7UA22. Not good :confused:
I have looked in the manual, and there they say that the system clock only exists with cpu's with 2 serial interfaces. Well, there are 2 serial interfaces on my CPU's. What's the problem then?? DB1 ??
Thanks for the answer!
I want to log the time & date when an alarm comes up. Normally I put the time & date in a DB.
How can I solve this now, when I don't have a system clock?
Hi Greet,
As I see it you have 3 options...
1. Get a 'B' series CPU as a replacement.
2. Does the system have a HMI? On S5 systems in the past, I have used the real-time clock from a Lauer PCS series HMI for similar timestamping functions. (they map the RTC to the interface DB)
3. Program your own clock/calendar. It won't be very accurate as it stands so it's a good idea to use an external real-time clock wired to an input to synchronise your's on a daily basis. Tip: don't synch at midnight as it could affect your day rollover.
Kevin H
HEllo! Where do it setup the clock? Couldn´t find anything useful in General-->Time of day besides daylight saving time. And when i have set the...
1,362
Hello everyone one. I'm using M340 with simulation mode (actually I still don't have the cpu to test the software). I've made a simple counter...
524
I took an online course but don't remember covering this. How do I access the system clock in a compare instruction? I want to turn on an output...
538
I am using a Studio 5000 with an Allen Bradley CompactLogix 1769-L24ER-QB1B controller. Im wondering how I can use the system clock to be able to...
2,452
hello everyone, I'm trying to set the system clock on my plc for daylight savings time so the operator does not need to adjust himself twice a...
2,435
