Tablet PC and RSLinx
xxslimxx
Guest
X
Has anyone tried to install linx on a tablet PC running Windows XP TABLET VERSION? I have tried and the install failed when it came time to load the drivers, To make matters worse I can not UNINSTALL linx because when it goes to remove the drivers it can not find them.
We have RSlinx on a tablet, along with RSView SE.
I think it's RSlinx Pro. The tablet MIGHT be Windows2000, but I doubt it. All of our other machines are WindowsXP.
I'll look into our setup the next time I get a chance.
AK
Our tablet is running Windows2000. But, I don't see why WindowsXP on a tablet should be much different than WindowsXP on a desktop. What service pack do you have installed?
I am waiting to install SP2 two other machines are working fine with the update so in a week or so I'll update it also.
I'd like to figure out how to uninstall linx, If I try to delete it and run setup again it finds the previous install and throws up on me.
Hello everyone, we need to use android tablets that simulate Rockwell's panel views (tablets will be replaced by hmi which are having very long...
3,507
I'm looking for a way to visualize some data of a manufacturing process in an Android Tablet, the monitoring system has an OPC UA server that...
3,061
I'm curious if anyone has used a Surface Pro with Wonderware? I developed the application in 1920 x 1080 and that is the resolution for the main...
1,549
I got the go ahead to implement a few window 10 based rugged tablets running a wonderware applicatiom for a process line. Anyone have any 1st...
1,116
Hello, I would like to connect a PLC through WLAN, directly to a PC Tablet. The PC Tablet should run the wonderware. Is it possible? Has anyboby...
3,544
