TCP Smartscreen
cwarren
Feb 2007
Vernon Hills, IL
I currently have a TCP Smartscreen that I need to edit the program. I have the programming cable, some software(386sedit & tcpcomm), and a hardkey. I am able to connect to the smartscreen and send keyboard commands. I can't figure out how to edit the screens and alarms, or upload and download files. Can anyone give me some pointers on this relic?
Couple of ways
There are a couple of ways to do this. One, you can edit the file using the actual screen itself. Connect the keyboard to the terminal CPU backplate, and click Esc 3 times. This will bring up the terminal menu. If you don't already have an offline archive file, then I'd use this method. Then when your changes are complete, suck the file out of the terminal to back it up.
If you want to use the offline editer, there are a few things that you need. I'm by no means an expert, but I do know that the software needs to sit on your harddrive, it will not run from network location. We use an application called TeraTerm Pro to upload and download the files to the terminals. I am not sure where we got it, just that it is what we use. I'll look into this more here. In the meantime, I'd try to make the changes right on the controller if possible.
I do the changes in the controller with a pc that runs TCPComm software . It emulates a keyboard and allow to upload/download files.
TCP Smart Screen Software
Anyone know where I can find the programming software for TCP Smart Screen Software, 386sedit?
Does anyone have a copy of the original DOS software used to get the program out of an old TCP SmartScreen. I have a floppy with some corrupt...
2,167
I recently bought and older TCP Smartscreen (the large crt type) It has memory module MMI22300C1A. When I try to load a program into it I get the...
1,440
I have a SmartScreen Operator Panel, Due to frequent Brakedowns I am planning to replace it with PVP or some other touch panel.... Can someone...
2,816
Hello, I've troubles with Olds MMS SmartScreen . As it not possible to get it repaired , I would like to replace by other product(s) . My...
2,442
Hi guys. I have a TCP smartscreen that I need to password protect. My first problem is getting the archive which is supposed to have my files in...
3,279
