Telemecanique Nano PLC Communiations
fredjohns
Dec 2008
Pennsylvania
119
I have a Telemecanique Nano PLC in one of our tabbing machines. I want to be able to connect to it and copy the program. I purchased the software which was PL7 07/V4.0 and also purchased the TSX PCX 1031 cable from Schneider Electric. The datasheet that came with the cable said that I also need a Uni-telway driver. I can either run the program on Win 98 or in Dos. Is it better to run it in DOS or in Win98. What driver do I need to run it in DOS and where do I get it at.Is there any setup needed once the drive is installed.
Fred Johns
Day Timers, Inc.
www.daytimer.com
That cable was used with several different PLC models. In your case the TSX-Nano should not require the Uni-Telway driver. I have run it in both DOS and a Win98 DOS window. Just watch your standard Comm port setup parity.
we have a number of these units ourselves and the tech at Schneider that I spoke to told me that version 4 will run under windows XP. I installed it like he said and it did run under XP. When I get back to work on Wed. I will see if I can find my notes and post them here for you. I think the driver is packaged with version 4.0 and it will install if needed but again without looking at my notes I dont remember.
Hope this helps. Have a great day.
Fred Johns
Day Timers, Inc.
www.daytimer.com
Just wanted to thank everyone for their help. I installed the PL707/Ver.4 program in a computer with Windows 98 and used the uni-telway driver for Win 95 and it worked good. I am able to run it from Windows 98 with no problems
I have TSXNano that has died on me and as these are obsolete, I want to replace it with a DirectLogic 05 plc. I was given a hard copy of the...
2,501
Greetings! Does anyone know how to use a bit sequencer in Tele PL707? I'm used to the way GEFANUC does it... Cheers, Byron
4,260
I have a Telemecanique/Schneider TSX07 21 2428 v2.4 plc running a machine here and I have to modify the program in it. My problem is I cannot...
5,459
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
247
Hello! Sorry for the unusual question not quite on the topic of the forum. We have a computer museum. We got an old PLC programmer telemecanique...
1,630
