Telephone Line Switch
Bill,
I'm not sure about Canada, but in the UK we can disable the 'ring' of the phone.
This will mean the phone will 'ring' at the callers end but there will be no 'ringing' on the phone itself. I don't know if that is what you want to do.
Mark
If you are using it for a phone signal do it as Dravik said but use a relay that is made for low voltage signals and has gold contacts to maintain a high integrity signal.
So here is what I'm trying to do. I have a PLC that regularly communicates to HMI system via an Ethernet radio. In case the radio fails, I've installed a dialup Ethernet switch/modem which allows a person to dial into the Ethernet network remotely over the telephone lines, for a backup.
The problem with the dial up is that it is not secure; that is, anybody at anytime could dial up the modem and get into the network. So what I want to do is use the PLC to "break" the telephone connection when the radio is good so that nobody can call in while the radios are working.
I was also thinking of using a relay to break one of the two telephone wires, but I'm not sure which one to break. Should I break the L1 or the R1 wire or both?
Also I'm have space solid state relays on site? Will the solid state give me headaches?
Wow, I'm reading that telephone lines carry 48VDC. So much for low voltage.
OT: I learned that when I was 18, hooking up an extension for a buddy. In those days, my electrical experience was mostly automotive and I usually stripped small wires with my teeth.
Yes, I had the phone wire in my mouth when I heard (and felt) the phone ringing in the living room.
I used to be a Phone Guy back in the day. I think if it was me, I would hook up a relay in parallel and use it to short the two wires when needed, then open to restore dial tone. This will cause the line to appear busy on the other end.
I had a guy I used to work with tell the exact same story. Was crying I was laughing so hard.
Also, it looks like in the US, the common ring voltage is a 90V 20Hz. I would recommend a good quality contact, especially for data.
Will data-linc leased lines modem (LLM1100) work with Verizon's Metro Private Line Digital Services? The idea is that modem will be connected to...
1,325
there is one line into the house but has 8 parallel extensions to various rooms 3 of these lines have 10v approx ac to earth this appears to be...
33
6,925
P
Hi All, Could you please suggest me a available solution for this application? I have to monitor a warehouse via a camera from very far control...
4,387
Hi All, My problem: There are 4 working stations, i have to collect temperature, pressure, current, voltage value to a control room that very far...
4,815
Does anyone have an elegant method of letting the PLC(AB5/30) know that the phone is ringing? I'll use it to alert an operator to make their...
1,619
